Between Omaha and Des Moines, 7 miles South of I80 | page 13 of .pdf. 1. Speed Source Select from the available speed sources. When a speed source is available and selected, the system will not actively control down force at speeds slower than 0.5 mph (0.8 Km/h). The down force will hold below this speed. A. CAN GPS (NMEA 2000) B. ISO GBSD (Ground Based Speed and Distance) C. No Speed Input—system is allowed to control planter anytime it is lowered with no minimum speed requirement. 2. Enable Automatic Control Uncheck this box to enter monitor only mode. Down Force Alarms Down Force
Edited by 4WD 3/11/2018 13:10
