SE Minnesota | If you are looking for cheap you can probably pick up a used ez steer and ez guide for $3500 or less maybe, for tillage waas correction is fine. I use this set up for fall spraying and it works well. If your tractor is auto steer ready and not just greenstar ready I would go with a John Deere system, it is going to be a little more expensive but you don't have anything hanging on your steering wheel. If you want to go John Deere you should be able to buy a 2600 that is unlocked to auto steer for around $5000-5500 and a iTc globe for around $600. If the tractor isn't autosteer ready you can still go with John Deere you just need to buy a ATU 200 which should be around $1000-1500. | |
