Near Intersection of I-35 & I-90 Southern Mn. | In the first post you stated that you had the right cables. If you didn't have the tee cable to the processsor, how were you trying to get GPS in to the Greenstar system?
Also the GPS port (B) is normally setup to communicate in TSIP to work with the PF3000. The PF3000 will allow you to setup the AUX Port (A) to NEMA for connection to another device. This is the 15 Pin connector.
If you use Ag Remote to reconfigure the GPS Port (B) and are physically connected to that port when using Ag Remote, your connection will be lost when you set that Port to NEMA. This is because the Ag Remote program communicates with the 3100 via the TSIP protocol. Once you instruct the 3100 to communicate in NEMA which your Greenstar needs, the Ag Remote program can no longer communicate with the 3100.
This is somewhat akin to locking yourself out of your own house. You may have to "break in" by doing a TSIP break. Once you have broken in, the communication is set to TSIP again.
The trick is to change all the settings but the NEMA setting until last. When you are sure that the others are what you want then change to NEMA knowing that you are about to slam the door on yourself.
Edited by tedbear 9/30/2006 11:49
