North Central Ohio | We are transferring an autopilot system from an 8103 Terragator to a TG7300. Trimble catalog says the systems are the same, just hoses are a little different. The TG7300 does not have the pressure washer option installed....the 8103 did have that. The install instructions want you to connect there (pressure washer hydraulic hoses) for pressure, then return the EF flow to the place when you got pressure from. Basically, the oil flows thru the autopilot valve & steering uses only what is needed. Problem is, I don't have the pressure washer installed so I don't have the recommended source of hydraulic pressure. Can anyone suggest a solution? Or take a few picts of a TG7300 that has an autopilot valve on it? Can I eliminate the sandwich valve and just "T" into the hand pump pressure? Thanks
Edited by sunman 1/17/2018 13:16
(Untitled.jpg)
Attachments ---------------- Untitled.jpg (73KB - 136 downloads)
