Posted 1/16/2018 18:39 (#6510268) Subject: NH ts 110 4wd problem
My tractor will work fine in 4wd if you are going in any forward gear (all 4 wheels will spin) but if you go in any of the reverse gears the front wheels will not spine and the tractor makes a chattering sound. just seeing if anyone has had the same problem.. My drive shaft between transfer case and the front diff are fine and the front diff is good i lift it up and everyting run well.
