SESD | What size planter?
I don't know if it'll work with a C2000 but we took off the factory White harnesses and modules for a 12 row 9222, everything from the hitch back to the row units except for the sensors and cable drive clutches. Got the planter without the AGCO C3000 monitor so I can't help you much in the cab but we do have the DJ switchbox. We went with Ag Leader to monitor seed and clutch control. I'm guessing part or one of the harnesses should connect to your seed sensors and the other would connect to clutches if you have them, after that I'm not familiar with the DJ stuff. It was easy to take off but I wouldn't be much help on how to put it back on. It all went into a box in the corner and hasn't moved and would be for sale if it can help you.
Mike | |
