Posted 1/11/2018 10:09 (#6496123 - in reply to #6493391) Subject: RE: Raven nh3 controller
This cable should be a 1-115-0171-840 12' extension cable, the 2 pin weather pack is to power up booms 4,5, and 6. If your system does not have 4,5 and 6 sections it is not needed. If you do have the sections you need to supply power and ground to this 2 pin connection(if this cable is a 12' extension)
