Search Forums | Classifieds (160) | Skins | Language
Creating a pdf to from My John Deere operations center.
McFlyAg
Posted 1/9/2018 07:05 (#6491018 - in reply to #6490249)
Subject: RE: Creating a pdf to from My John Deere operations center.
Typically what you do is you view the field you would like to print in the Field Analyzer tool. From here you can select the field, layer, or comparison and click on the three horizontal bars in the upper right hand corner and print.
Open Operations Center > Click on the tools button in the top left (four boxes in a square), > Select the Field Analyzer button > Open your field and map layer using drop downs on top > press print in upper right hand.
If you're looking to just save to PDF instead of print, just go to the print option and switch your printer to the option that says "Save As PDF" from your printer list.
Hope this helps.
