Posted 1/8/2018 13:39 (#6489205 - in reply to #6488413) Subject: RE: Fireplace not efficient
NW Washington
Fireplaces are notorious heat wasters and when the fire goes out warm air from your house goes us the chimney. A good fireplace insert is your best option, but make sure you put in a new chimney liner if you install an insert. Without a liner the insert will not draw right and a chimney fire can be a real danger.
