Search Forums | Classifieds (2) | Skins | Language
T2 harness connector
AustinR
Posted 1/9/2018 07:46 (#6491098 - in reply to #6489135)
Subject: RE: T2 harness connector
Illinois / Wisconsin
This.
I found the threading one time. I believe the threading is fairly common, so a bolt/screw with some nuts from lowe's should also do the trick.
I believe it's the same thread as this: https://www.digikey.com/product-detail/en/amphenol-fci/863001019TLF/...
If that's the case, a 4-40 nut and screw should do the trick. Lowe's, Farm & Fleets are the best bet for finding the exact right lengths and sizes.
(Note: it may be a M2.6 thread screw, but most likely, it's a 4-40. https://www.canford.co.uk/Products/20110/44-020_D-SUB-Hex-socket-spa... )
Regards,
Austin
Edited by AustinR 1/9/2018 07:47
