Posted 1/3/2018 13:51 (#6475695 - in reply to #6474962) Subject: RE: JD rate controller question
EC Illinois
A JD rate controller should be able to control 10 sections. What Raven cable did it come with, does it only have a 3 section cable? If that is the case, yes you should be able to just change out the cable to a 6 section or 10 section cable and all should work.
