Search Forums | Classifieds (36) | Skins | Language
SMS equation analysis
ntbill
Posted 1/2/2018 14:39 (#6473027 - in reply to #6466869)
Subject: RE: SMS equation analysis
SC Wisconsin
Yes it can be done. You need to factor in the buffer capacity of your soils for P & K. K-State appears to use a factor of 18 for P2O5 and 9 for K2O. This means you need 18 units of P2O5 to raise or lower the Soil P test by 1 unit (ppm), 9:1 for K20. Be aware that the buffer factors can vary by soil type and soil test levels, but this should get the ball rolling for you. Good luck!
Found the information here, Page 8. https://www.agronomy.k-state.edu/services/soiltesting/documents/fertilizer_recommendations_and_references/soil-test-interpretations-and-fertilizer-recommendations.pdf
