Central South Dakota | on them machines you can go in to the diagnostic address to the RCU. 0003 Vehicle go to #116, there is a number 1 there put a #2 in. What that does is on the loss monitor it divides that graph in 2 so the right graph on reads the right sensor. same goes with the left. after you do that you can the test be turning on the key and engaging the separator and do the tapping and you should see the difference on the graph that will tell you which one works or not. attached are pic. of the address.
(Picture1213171519_2.jpg)
(Picture1213171519_1.jpg)
Attachments ---------------- Picture1213171519_2.jpg (99KB - 12 downloads) Picture1213171519_1.jpg (68KB - 4 downloads)
