Posted 12/13/2017 13:53 (#6426451 - in reply to #6426357) Subject: RE: Wood rake, high clearance spring loaded shanks.
South East Illinois
Use a mounted field cultivator and pull it backwards or change the hitch so you can push it. You can change spacing's of the shanks if you need them closer. We used a mounted JD behind a 4020 to cleanup miles of fence rows.
