Posted 12/11/2017 15:24 (#6421845 - in reply to #6421762) Subject: RE: why do my yield monitor maps look like this
Nashville, IL
As soon as i seen it I figured it was a case dipslay. You run autosteer too? Ive seen this issue quite a few times in quadtracs and 4wd tractors. Something with the gps signal messes up in the NAV when using auto steer. I changed an auto sense on a quad the other day and solved this issue, but if you arent running any steering control, Im not real sure what could cause it.
