Hennepin, IL | I'm a rep for both and honestly in your case, it would come down to preference. Don't be scared away from the PP system because of a lack of an accumulator, there is a bypass in the cylinder that bypasses the oil to the return when a rock is hit. PP has done kind of a poor job of advertising this fact IMO, as I just recently learned the technicals of it. Also if you are in a situation where you think you may utilize lift, Dforce is a better choice. On the flipside if you want the convenience of 1 display, data transfer, would like to keep the ONE meters on the planter, Ag Leader may be a better fit. Also depends on your operator, if you want a set and forget type system, Ag Leader is your choice, you won't be as happy with Dforce, on the flipside if you like to be able to tweak settings from field to field on the fly, Dforce may be a better option. Either way, I doubt you'll go wrong. | |
