NW KS | This wiring digram will give you a good idea of what you need as far as part. You would just need to replace #12 with a section control module and #13 with an adapter for your clutches. The rest of the parts shown would be the same. As far as what to use for row clutches there are a lot of options. You could use the tru count ones trimble makes or a row clutch from another manufacture. If you use a clutch from another manufacture you will most likely need an adapter. Ag express is a good source for adapters to go from a Trimble section module to another brand of clutch. There are several different row clutches that you can get and they all have their pluses and minuses. You might also consider a Trimble seed monitoring module to replace your 250. You can keep using your 250 but if the row clutch shuts off a row for part of a pass it will show that row as having a problem. The 250 has no way of knowing that the row is supposed to be shut off. Not a big issue but something to be aware of.
(Field-IQ System Installation Instructions-1.jpg)
Attachments ---------------- Field-IQ System Installation Instructions-1.jpg (134KB - 76 downloads)
