| I have been running NH3 bar with a versa for 5 years now. With perscriptions. We have had no problems. Most application problems I have run into regarding proper rate application either have to do with the calibration of the product or a problem with the flow meter. Are you sure your calibration is correct and if so are you sure that your flow meter is working properly. Also want to be sure there are no blockages in any hoses. | |
