NE South Dakota Clark, SD | I am not a Trimble ag grade control expert by any means, but I think you need a predesigned plan for the entire field with the terraces designed in it. I don't know if it is capable of that. To the best of my knowledge, FL2 is for land shaping/leveling and WM Drain is for ditching and tiling. I know that their construction controllers can load engineered plans and do what you want. Best of luck and I hope you can make it work, but am not really hopeful. Your dealer may not have known what you wanted to do or not known the capabilities of the system. |
