Search Forums | Classifieds (139) | Skins | Language
What size tillage equipment can 8940 Magnum pull?
Bigshot
Posted 11/18/2017 20:46 (#6374187 - in reply to #6373857)
Subject: RE: What size tillage equipment can 8940 Magnum pull?
With duals, a 30 ft field cultivator, no problem. I can pull 40 ft with a dualled MFWD 8950.
With the disk, it depends on whether it`s a finishing disk or not. Medium to light duty disk on 7.5-9" spacing should be fine. A heavy disk, I`ll say no. My 8950 will not pull a 30 ft primary tillage disk. You`ll need minimum 300 engine h.p. and 5000# more weight to do that.
