Search Forums | Classifieds (6) | Skins | Language
Case QT autosteer issues
Dusty
Posted 11/13/2017 14:35 (#6362613)
Subject: Case QT autosteer issues
We a have a QT500 that has a couple of slight steering issues I would like to try to iron out.
When turning onto line it will not engage until it is virtually on line and it won’t turn in from an angle and acquire the line smoothly. (Have played around in advanced settings but no improvement). When online and engage is pressed it does a severe twitch in the steering before straightening up again and then driving straight. It usually only does this after turning left. The final issue is it comes up with ‘swath calculations in progress’ on the Pro 700 when making a turn and sometimes doen’t have it sorted by the time engage is hit again.
All firmware is up to date and recently done by dealer and has had a couple of recalibrations done. However it doesn’t perform anywhere near as well as our older STX on a Pro600 with 252.
Would like to think it just needs some more tuning and any suggestions would be much appreciated.
