east central, Iowa | Been having a problem with a JD 2014 8r series tractor losing gps signal. Using Sf1/Sf2. Been going on for a few years. Seems to be getting worse. My display will say no gps signal on the screen. All lines and coverage map will be gone. After a minute or so they may come back up. Myself and JD dealership have tried everything. Different globe, 2630, wire harness for 2630, checking plug in the roof of tractor and replacing it, replacing the plug on the back of tractor, unplugging the implement, has updated software, etc. we tried everything. At times it will work for hours and other times five minutes. It's hard to track down a problem when it works at times. We bought the tractor new and we weren't using auto steer the first couple of years in it but I think it's the main wire harness in the tractor having a broken wire in it. Jd dealership is thinking the same. Just seeing if anyone else has ever had the problem. Thanks | |
