Posted 10/21/2017 21:24 (#6319773 - in reply to #6319747) Subject: RE: Just installed a used PF3000; battery dead... can I still use it?
Westport, IN
Short answer yes.
If not using data card I don't think it matters at all. You might loose setup every time you turn off, but I don't think you do. It makes a new file on the card every day. If it is the same date every day because of a bad battery this file can get to large and become unusable.
