| I have Boss and Western V plows that are part of the gear that plows about 40 acres of parking lots and the newer versions are both fine.
Check into the cost of replacement blades, one of my Boss units has curved ends on the blades so they are fairly expensive.
Just a note about trucks -
If you are doing any plowing on a regular basis - don't look at anything smaller than a 1 ton SRW truck with factory HD suspension/plowing package. Otherwise you will be throwing all kinds of money at it for "improvement" kits and still be rebuilding the whole front end every season at least once (I have both GM and Ford trucks and it was the same story with either brand).
