NC IA | You will most likely need to get the Retrofit Kit in order to have it run correctly. If the dealer would allow you to look at the exact pin-outs of the kit and you could compare it to the existing one on your combine then you could probably modify yours to make it work. I don't know how much time or money you want to invest in this but I personally would just have the retrofit kit put on and save myself the time and headache of figuring it out. | |
