Search Forums | Classifieds (42) | Skins | Language
EZboom control of CNH 305 hydraulics
Dave F
Posted 10/12/2017 23:05 (#6304703 - in reply to #6303339)
Subject: RE: EZboom control of CNH 305 hydraulics
Southeast MN
Interesting concept Pat.
Not sure this idea has merit but what if you have the tractor circuit in "hydraulic motor" mode so it always outputs oil at whatever flow you need. This circuit feeds into an electric shifting 3 way valve on the tanker. Then the ezboom signal shifts the valve to run the tanker and when it needs to shut off the tank, the signal shifts the valve to "bypass" and returns oil to tractor?
Not sure if this will overheat oil but it's easy for me to envision the electric circuit controlled by the ezboom.
