Posted 10/4/2017 09:28 (#6286683 - in reply to #6286525) Subject: RE: YieldSense moisture drops with lights on
Hennepin, IL
Do you have a PP moisture sensor or something else? If it's a PP it should already have power directly from the battery. I would watch motor status while the lights are on to make sure the motor is cycling on and off like it should. It's possible that the small drop in voltage is making the proximity switch act up.
