Southern MO | We have been using our 2630 for autotrac and have switched to using the Gen 4 command center for autotrac to free up the 2630 for the combine.
The issue we dislike is that when we change fields with the Gen 4 the line from the past field stays active until you pick a new line.
Our guys are older and used to the line automatically being loaded when they change fields. I can see them forgetting to change lines and making a mess with the rows being off a few degrees.
The gen 4 should say no AB lines selected when entering a new field not auto filling the previous field line.
What possible reason would the previous field line still be active after a field change?
Is there any way to make the line load with the field like a 2630 does?
We have multiple lines for our fields but only 1 straight track the rest are AB curves so on the 2630 if you are in straight track there is only 1 line available per field. | |
