Butler County,Iowa | Hoping someone can help me. We installed a Complete used system on our TR86 combine. Unit came off same make and model as ours. I installed everything and so far all I can get is speed and temp readings. I saved the old calibrations in it. But haven't calibrated myself because of this issue.
So when I start combine up and lower head. The switch activates when I lower the head and light goes off. But as soon as I try to combine it starts to have a alarm go off and ask me to insert data card. Pretty much once it does that it's locked up. I thought these could be used without a data card?
Just hoping someone has had same issue. Like I said everything seems to be setup with fields and loads and the speed sensor is working showing correct mph. And the temp is reading ambient temp correct. Just when I start to move I get this request.
I tried a card that we had for a pf3000 didn't work
Help please!!! | |
