ecmn | beans had all day to dry. could easily see moisture to drop. dew just setting in means the next morning moisture will be back up?
yield in beans for us is not uncommon to see big changes.
if you believe that its not accurate get a weigh wagon and do your 5 calibrations again.
yes I believe that the temp should be ambient air or real close to it.
hard to calibrate moisture. when I first got the system up and running I would find a spot in the field when the monitor wasn't moving much. then catch a sample out of the tank auger and test it. | |
