Eastern Nebraska | Are you sticking with the brown box? If so you need the mobile processor that attaches to the back of the display along with an AutoTrac SF1 keycard (hard to come by). You will need the steering valve and the wiring harnesses for the tractor. StarFire GPS receivers come out of the box with SF1 signal, so there wouldn't be any additional activations required unless you want to achieve higher accuracy. | |
