roaming | Precision Ag Service - 9/26/2017 08:06
hello,
I am trying to move field boundaries from SMS to a Pro 700. My SMS is version 17.5 and Pro 700 is version 29. I tried creating a folder named shape file on a clean USB, as well as building a shapefile folder on his memory stick with the cn1 file, but neither way seems to let me load the boundaries. Am I doing something wrong in the process? I also forgot to mention he had old field boundaries in the display, is there a way to delete them out, or could that be our issue?
Thanks,
Josiah
There wasn't a version 29; you might be on 28 or 30. Shapefile import wasn't available until v30.6, so if you're on 28, that would explain your problem. |
