Posted 9/24/2017 17:27 (#6267722) Subject: Semi air compressor issue
North Central Iowa, Humboldt County
I was heading to the elevator with a load of Soybeans and noticed the pop off valve releasing which isn't normal. I looked at the air gauges and the top one was reading 130 and the bottom one was at 140. Has the compressor Governor went bad and if so, is it difficult to replace? It's on a 60 series Detroit.
