SW Nebraska | I am running a Flexhoe400, 3430 cart, and Pro700. Randomly I will get several faults/errors related to my blockage sensors then when I go to my flow summary page it has added an extra sensor. I have 16 sensors and it will say 17 of 17 flowing. I only have 1ecu and it is usually rows 21 and 22 that mysteriously show connected if I look under diagnostics/connected. If I look under setup/sensors those rows are gray(no check mark in the box). I found those two wires and pulled the caps. Wires look good and it's nice and dry under the caps. Is it a wire issue? Any other suggestions so it doesn't recognize phantom rows?
Thanks
CNP
Edit:
Framework v30.6.0
Task Controller v30.6.0
VT v30.6.0
Edited by CowsNPlows 9/22/2017 12:19
