| What firmware are you running? How much memory is remaining? Is the head on display showing as being down in the run position? Are you running with USB in display set to auto download? If you have the latest firmware and 80%+ memory remaining, restart display and start a new event. If that doesn't do it, export all data, check data to verify yield data on desktop software, then delete all fields and data, try again. If that doesn't work do a hard reset. I'm not a huge fan of using a FM750 for yield monitoring, it is very glitchy. This summer for wheat we swapped a FM750 for a FM1000, and seemed to do much better. The FM1000 has more memory room and more computing power, a XCN would be another option, but I have not tried with that to see how it operates. Hope that helps. | |
