| There's one other benefit of going WM Drain / Trimble and that is you that if you ever want to do landdshaping or landforming its an easy upgrade to Field level 2. We have used it many years with OptiSurface.
In your situation where you mainly rely on drainage lines to get water off the field, we find that shaping or smoothing the surface in between the drains can also enhance surface drains and crop yield. If you want to learn about landshaping then take a look at the free video training at optisurface.com
