SE IL | I wouldn't think so but not sure. I replaced a mass flow sensor once but don't remember doing anything special to get it to read. With that said had to replace a moisture meter on a 9860 once and had to go into setup (I think, been awhile) and do a calibration procedure. I think it caused some software to be loaded onto the meter. Look under info and see if it shows a software version. If not you will need to program it. It should be on the display I think. You may need to put a stick in with the update for the display. I don't think the dealer should need to do it. | |
