Posted 9/13/2017 21:14 (#6246523) Subject: Run a Gandy with a JD rate controller and 2630?
SE IL and SW IN
I have a Gandy seeder with variable rate, formerly run through a Raven 660 which is now toast. I have on my inventory a JD rate controller and 2630 in my cab. I see that the Gandy uses a 16 pin connector and the JD controller uses a 37 pin but I am told that there is a connector. Can I put this all together?
