Search Forums | Classifieds (114) | Skins | Language
Accucontrol PRO 700
WtvlPres
Posted 9/7/2017 11:37 (#6234248)
Subject: Accucontrol PRO 700
South Africa
Hi guys. I an trying to run a lime spreader with field iq modules, with a pro 700 and accucontrol.The spreader was run with a FM 750 and field iq setup, and nowwe have a new Puma 180 that we would like to use. When I do the accucontrol setup, I have the option to setup a spreader and a granular product.When I try to calibrate the spreader, things are getting strange for me. The instructions on the display say that I need to apply the product in the field after starting the calibration process. When finished with the application I need to input the amount of product applied, but how will I be able to collect the applied product from a spinner spreader after being applied? I tried setting it up as a granular toolbar as well, but that doesn't work either. The setup is not the same as the toolbar has a metering unit calibration...Has anyone done this before?
