Search Forums | Classifieds (18) | Skins | Language
FD70/2162 question
neb04
Posted 8/18/2017 19:55 (#6195971)
Subject: FD70/2162 question
nebraska
Have one side that seems to bind up a little and not flex like it should, 2010 model. Thinking it might be the rubber bushings on the vertical adjustment rod, I think it was mentioned here the other day.
Is there an update for these, what's on the newer heads (any pictures)? Or can you put new rubber bushings in (or get new end)?
Is fixing just the top end all you need because you can't get the bottom bolt out without taking adaptor out of the head. The bottom of the rod pivots front to rear so I don't think it would matter anyway. Thanks
