| You need to change CCU24 address from 001 to 000. The 8000/9000 tractors sometimes go to KPH on there own. Put a fuse in the DIA slot and use your turn signal and high/low headlight beam switch to change it. Then use the red flasher switch accept the address change. Its easier than it sounds. Just make sure you don't change any other address while your in there!!
https://talk.newagtalk.com/forums/thread-view.asp?tid=389506&Display...
Edited by Ron Mahoney 8/18/2017 20:47
