| The Feedrate code is surprising that you are getting that code. It is for newer common cab machines. There is a setting under the toolbox--Drive tab for federate sensor. You can look and see if you have that in there and make sure it is not installed, but it really should not even be there.
The Rotor motor alarm is because the Rotor hydrostat motor oversped when you engaged the separator. Probably because you are running higher rotor speeds and when you engage at a high engine rpm, the motor is what actually starts the rotor spinning before the mechanical clutch locks the drive to the engine. By rights you should engage the separator at a lower rpm anyway. | |
