Search Forums | Classifieds (97) | Skins | Language
c2100 task controller and SMS export for S-78
WildMan R-72
Posted 8/12/2017 12:07 (#6182437)
Subject: c2100 task controller and SMS export for S-78
So I made up field names for harvest in SMS and exported them out and I downloaded them into the monitor and I get all field names to show up like they are suspose too. The problem I am having is it wont let select the crop type. If I add a field manually then I can select a crop type. Anyone else have this problem?
What do most people use the API tru path or the combine interface card for the implement in the task controller and what's the difference. The one combine the width will change in the combine interface card when I change it on the monitor where the flow delay is but the other combine won't when you look at the implement set up in task controller. What did I mess up there. Anyone got any ideas there or know what to do.
