Winkler, Manitoba Canada | daveb - 8/1/2017 12:58
When I go into WM-Drain and attempt to survey the Bench Mark buttons are grayed out. It won't let me benchmark. The GPS button shows GPS configured as Autonomous and the GPS status as Fixed.
No experience with the situation. I doubt that the TMX would let you benchmark anything when the gps is coming up as autonomous, ie no external correction. Is your JD receiver actually on RTK and is it sending that info in the NMEA stream? |
