Search Forums | Classifieds (198) | Skins | Language
Shredding corn stalks
Gman21
Posted 7/23/2017 06:58 (#6143440 - in reply to #6143296)
Subject: RE: Shredding corn stalks
LaSalle, Ontario, 10 miles south of Detroit Mi.
Why do you want to shred the stalks , so there is a layer of material to hold moisture ? If you shred them after harvest the time before you plant will give the wind time to blow them all over. When no tilling here into stalks I leave the field untouched then just plant into it in the spring with a JD 750 drill works well here.
