whitehall maryland | I currently feed and all dry ration through a twin screw vertical I set up a tank , 2 inch transfer pump . Have a two inch line with a wide angle fog nozzle mounted to front of mixer to spray over load . I pump enough water on to get a 68 percent moisture mix. Works good without water cattle sorted terrible it fed out terrible and didn't get close to a consistent mix. You could use a molasses type liquid feed but that gets pricey quick. | |
