Iowa | It will be a Seedstar 4 HP planter. You will be required to have a 4600 or 4640 display in order to use the planter. If you don't know the difference a 4600 does not have the subscription model but it is permanently installed in a tractor and can't be moved. The 4640 in the new stand alone display that can follow around something like a planter to different tractors. The 4640 is the only display currently the has the subscription model. The new planter is not ISO compatible. | |
