NE South Dakota Clark, SD | This could be part of your issue. Speed is calculated from position change. If your positioning is a little erratic, speed would be also. Are you running off MN DOT or other solution? Is it nearest base or networked solution? It would interesting to try a radio base in the field to see if this is the issue. I have several customers running 750's with very few issues. Some on commercial plows running 2+ mph consistently. |
