Posted 7/4/2017 07:42 (#6104624 - in reply to #6104563) Subject: RE: Valley Pivot guidance error
Eastern Oregon
I had a similar GPS intermittent issue that nearly drove me crazy three years ago. It turned out to be an intermittent grounding path for the antenna that was causing a position failure once every two or three days. Fixed it with a little grinding and placing sharp shake proof washers under the antenna ground terminal.
