| SMS will only delete things that are unused. The reason you may not be able to delete "planting peanuts 2016" is because it is used somewhere in your management tree. I would try filtering your data to show you only the operations that are "planting peanuts 2016" and edit the operation to "planting". (Go to the bottom layer of each branch of the tree that shows up, right click, select "move branch", and change the operation to "planting".) After you change all of those operations you should be able to go into the management item editor and delete "planting peanuts 2016". It shouldn't automatically put all of your data under "planting peanuts 2016" if that operation is deleted. Hope this helps and if you need any further clarification feel free to ask and I will respond when I get a chance.
